so what I want to know is who has accomplished this running a factory floor shifter to a 700r4 transmission.
what shift cable did you use and what brackets did you use
I'm in the middle of this swap and, hung up as the cable that I'm using does not reach the transmission bracket.
I have several brackets and cables from factory floor shift g bodys 200r4 and th350.
Only In a perfect world everything would bolt right up.
I've even tried a mixture of the two brackets to maybe create a custom set up but still nothing.
