Yay! It’s like I got a participation award 🏅added, and you aren't even last place
Whoa whoa there (hehe). I found something this week (that I will reveal later after a further study of the logs.) I made full boost twice before the top of 1st gear - 24 psi.The key to full boost by the top of first is a blower lmao
According to the Holley, yes 1100-1150. It ran out at 1200 (for split second).You
You are using 1150lb/hr of fuel!?
That was a very fast pass considering the 60'. 144mph is moving.
60' is pretty good, but it should be faster given ur trap speed. 144 trap speed should be closer to a 1.30 60' and a 9.2x. Your very close and it's definitely not slow by any means.Whoa whoa there (hehe). I found something this week (that I will reveal later after a further study of the logs.) I made full boost twice before the top of 1st gear - 24 psi.
And I want to say, ‘I found’ 3 things in a couple of days with some help from friends - Jake , Bruce (fleming442) and Frank (from YB - LS3fox username). Each one of them gave me some advice and answers to some questions that helped me a ton.
wingnutks Do you think my 60’ is too slow for stripe speed? If yes, then hold on - I turned it down to keep from running out of fuel to get the 144. I think (me thinking is scary) I can get close to chute territory with another pump which should get me another 5psi ‘safely’.
*note I’m using the word ‘safely’ in a loose fashion - 33-34psi and safely on a SBE is going to shock the hell out of me, but I was SHOCKED to to see a 1.4 60’, a 9.4 and 144 trap speed. I thought they handed me the wrong slip!
If you were over your head your rods would have told you by now lol. I think your on the right track and track tuning is by far the best way to go.wingnutks
I will be the 1st to admit, all I have is guesses about HP. I’ve read, repeat read, in many places two things : E85 is about 1hp/lb, and these pumps are good to 550 a piece. Seeing numbers that that added up lead me the *ss U ME ption that the estimates were close - I know what they say about assumptions.
I’m 100% sure that I have slip speed and 1/4 time to drop in the suspension, timing and boost control. I mentioned Frank from YB previously, he looked at me cross eyed when I told him my speed and time at 27 psi. He set me straight, with real life experience with timing numbers. I split the difference from what he told me I could run to what I added and I’m sure he was correct based on the results. I’ve reached out to a local, professional tuner to get it on a dyno to properly tune it (plug reading and the such) . I’m sure I have a bunch left on the table. But for events like this (Drag Week) I think it’s more about finishing than hitting a number.
I reached out to a tuner because I’m ready to try both - finishing and hitting a number. I think I have close to an 8 in this with more pump, some simple and affordable suspension mods, and a proper tune. I’ve been backyard and ‘on ramp’ tuning this for too long. I’m not unhappy with the results - but I know there is more left in it - safely. And FWIW, I’ve been waiting to get it to this point where I know I’m over my head.
I really appreciate your response
Edit - I forgot to mention- I sprayed the same amount of meth as I always do (a conservative amount for safety detonation purposes) and the IAT’s stayed the same. I implied from that the turbo is no where near done yet. The S475 turned the intake temps into incinerator like temps when it was done, so that’s the basis that the S488 still has more too go at 29.5 psi.
It's time for the Dyno, a good tuner, a backpressure sensors and coolant pressure sensor.wingnutks
