So here's how my vfn hood came out I loosened the front clip at the radiator support removed the hood latch I had to slot my hinges latch support and safety catch then loosely bolted it on and tightened from the wheel well area( I have the driver side out) then adjusted the stops close installed the latch and got it as close as I could the spring I got from the hardware store it's attached with a compression plug and finished off with a rubber bump cover it was like 9.00 bucks worth of stuff from the store to make that
