what your looking for is a bad ground,the dome light system and dash lights work off of a ground, the dome light works off the door jam switch. the dash lights work off the head light switch, but if you turn the head light switch to the left you can turn the dome light on ,does this make sense to you? the ground for the switch is on the a-pillar under the kick panel{driver side} the dome light gets it's ground from the jam switch,if everthing is right when you open the door the jam switch complelets the circuit by grounding! now the dash lights gets it's ground though the switch.this means that when you turn the knob to the left it goes though the reaostat,i know that is spelled wrong, all i can say is that it's a b*tch getting old
this is were most people get confused the {reaostst} doesn't control power but controls the amount of ground given to the dash lights i hope this helps you,let me know what you find or if you need more help...jesse
