I'm in the process of gathering the final parts to do the complete rebuild on my 350 and the rest of the drivetrain. I hope to god I don't snap another driveshaft after this. Basically I'm looking for anyone's last minute two cents on the complete drivetrain I'm building. My main concern being whether I will have too little carb for the engine. Here is a list of the specs of each part of the drivetrain:
Engine
- 350 standard bore
- 882 heads fully built with 2.02/1.60 valves, lunati springs, etc.
- Speed Pro hypereutectic flat-top pistons (4 cc valve reliefs)
- Lunati 60103 cam (.489/.504 lift)
- Compression at 9.2 to 1 approx.
- Edelbrock performer intake
- Edelbrock 600 with electric choke
- 1.5 stamped steel rockers with HD pushrods
- Full length headers, 2.5in. exhaust, Flowmaster 40's
- Milodon Z28 Oil pump (high pressure/standard volume)
Transmission
- 1985 700r4 transmission
- 2300-2500 Dacco Pro-Street converter
- “Beast” Sunshell
- Complete HD rebuild kit
- 13 vane pump
- Corvette Servo
- .500 boost valves
- New hard parts/ reused planetaries
Rear End
- 1986 Monte Carlo SS Rear End
- 7.625 3.73 Yukon gears
- Auburn posi
- Fully rebuilt
Just looking for opinions on this setup and any flaws you can see. I have a full set of 1.6 stamped steel rockers I could play with as far as giving more exhaust lift to help scavenge out of the iron heads I'm using. As for the carb, I have a 750 Barry grant and a 750 Carter AFB if anyone feels that my current edelbrock 600 won't handle the job. Thanks for any input guys.
Engine
- 350 standard bore
Transmission
- “Beast” Sunshell
- 13 vane pump
- Corvette Servo
- .500 boost valves
Rear End
- Auburn posi
- Fully rebuilt
