khan0165 said:UPDATE:
(on my 8.5, sorry no update on 9 inch yet)
I opened up the 8.5 today, for a fluid change and a visual inspection, to see where I stand. Fluid came out smooth and clean, and visually nothing seemed out of place.
The only thing of concern was alot of sparkles in the fluid, which were very fine and only noticeable in direct light. The fluid didn't feel grainy, it was clean and without clumps, and I only noticed the sparkles when I a shined a light at the fluid.
is this something of concern? should I be alarmed? what could this mean?
khan0165 said:you are right, the 8.5 is great. But right now I am going thru a few issues with it... It is starting to slip and may need some work. A clutch pack or rebuild, etc... I want to go bigger gears also, which would involve a overhaul of the guts.
I want to rebuild it myself, as a learning experience... which would take time. The car will get parked soon, but I can't park it without a rearend. And I don't want to attempt working on it before then, as winter is fast approaching.
I am considering using the 9 in it's place while I play around with the 8.5
If it's a "direct bolt-in", it should be a simple ordeal... If I like it, I would keep it and sell the 8.5... or if I build the 8.5, I can resell the 9 inch
... I know it sounds dumb, but I need to maintain a driveline in the car while I play. And a 9 inch sounds like a great deal. And in either case, I could sell one and make my money back
check for wear on the ring and pinion gear, for right now, just check the backlash and make sure that was set right, the rear wasnt howling or making noise was it?khan0165 said:so yesterday, I took off the cover on the 8.5 to to do a general visual inspection and see what I'm working with...
... This differential has a old style Eaton unit, with S spring.
like this
can someone give me some info on this? Is this still a rebuildable system? Can someone help me figure out how to check which parts are worn, and what I should replace? Help with partnumbers would be great too.
Can someone point me in the right direction?
thanks!
like this
thanks!
