Hey guys.
I've got the 3.8 V6 with stock 3 speed transmission. So whatever transmission number letter thingy that is. And the stock rear end.
I was wondering what was involved into changing to a floor shifter. Not nescessarily a factory floor shifter assembly (because buckets are expensive), but a stand-alone one. The kicker is, I've got a bench, and I want to install it in-front of the bench (like in old Nova's and such). I've included pics below. And how hard it is to install myself (or if I should take it to a shop). And I'll also be replacing the part on the column with the shifter with a non shifter one from a junk yard as well. Will the floor shifter be able to be mounted in front of the bench? A pic below shows yes, but I'm not sure if it was modified extensively or not... Will either of the two pictured work with my stock 3 speed, or is there any other ones? I'd prefer staying with Hurst...
My interior (for reference)
GP with stand-alone floor shifter in front of bench (exactly where I want it at)
Factory set-up (front Grand Am)
Hurst Indy stand-alone shifter (more preforable than Pro-Matic)
http://store.summitracing.com/partdetai ... toview=sku
Hurst Pro-Matic stand-alone (more bulky, but if it's easier I'll take it)
The look I'm going for with the Hurst Indy set-up.
