JESSE that is a really nice set up you got there, does your shifter have a neutral lock out? i have a Q stick and it does not seem to have a neutral lock out, only reverse.
JESSE said:the gauges are autometer pro-comp ultra lites the four on the right are water temp,oil pressure, trans temp and fuel pressure all four are manual gauges and are a bit of a b*tch to install...the ones behind the wheel are a tack,speed-o fuel and volt meter....only the speedo is cable driven. if i was going to do this agian i would use a electric speedo instead of a cable the other two things are turn signals i moved the head lamp switch to the lower left side of the dash
