Floor shifter with column shift column still there
565bbchevy
9,614
12,683
Michigan
So I have the B & M floor shifter installed in my Regal and I have a steering column for the floor shifter but it is not installed yet.
So can I just take out the column shift handle for it to function temporarily with my floor shifter until I get my other column in?
Really I just wanted to test how much effort the cable will have moving the bars going up to the steering column.
Way back when I did my Monte I did the new column and floor shifter at the same time.
565bbchevy
9,614
12,683
Michigan
Pop the pin & pull the lever. The shifter bowl will move freely unless you lock the column.
Thanks, I thought that was all I had to do but wasn't sure.
64nailhead
Goat Herder
Dec 1, 2014
5,709
12,216
Upstate NY
Hookup the neutral safety switch and back up light to the floor shifter. Then put a big ziptie on the lever that the linkage used to attach to. Knock the pin out of the column shift handle - done.
565bbchevy
9,614
12,683
Michigan
I have my Monte wired up like that but used a big lag bolt to lock the column to the firewall.
Unlike the Monte where I made a custom dash the Regal still has the shift indicator in the dash and I would like to keep that functional if I can.
64nailhead
Goat Herder
Dec 1, 2014
5,709
12,216
Upstate NY
Well that will be different. Very interested to see how it this works out.
Built6spdMCSS
5,804
9,715
Florida Beach
At some point the Column in my SS was swapped out to one that used to have a shifter on it, it's been sitting like this since I've owned the car. If I rotate it I can't get the key out, which means it's working correctly inside.
I've re-wired everything to work correctly given my setup.. :)
Screwz
135
267
Arkansas
I don’t know if this helps but I had a 79 Cutlass with the factory floor shifter and the column had a collar that moved when you shifted . All the linkage was there for a column shift but no handle to pull. You might want to try and find one of those columns .
565bbchevy
9,614
12,683
Michigan
I already have a floor shift column it is just not installed yet.
565bbchevy
9,614
12,683
Michigan
I am trying to do the modifications to the interior where they are custom but still give it a kind of factory look..
So if I can retain the dash shift indicator I think that would be kind of cool, that is also why I will be installing the floor shift column to eliminate the the spot where the column shift arm attaches, one of the few things I saved for myself from the Monte SS I stripped.
