floor shifter
Ridgeline
131
Anyone out there have a template or an easy way to measure where to cut the hole in the floor of an el camino to install a floor shift and console mounting brackets?
If no one can help before I can, I can get some pics and measurements tomorrow late in the day.
Doesn't look like anyone has got anything. If you could take some pictures I would certainly appreciate it.
Thanks in advance.
Going from left to right, the measurements are 9", 2 1/2", 3 1/2". I measured from exactly where the arrows are pointing.
Would you happen to have any pics of the where the hole for the shifter cable goes thru the floor and where the shifter mounts? This is a bench seat truck and I don't have a clue where to place it.
Thanks
Thanks
The hole for the shifter was pretty much just above and to the left of the first little bracket on the right of the picture. I don't think that needs to be too exact, but that is the general area. I can't get a pic because it is too dark and the car will probably be sold tomorrow 🙁
