i would like to convert my 87 cutlass column shifter with a th350 transmission to a floor shifter. will the 350 transmission work with stock floor shifter without making any mod to the shifter. also will i need a different linkage . if so, if someone have a part number are link i would appreciate it. i do have the steering column for that shifter that i will be swapping also. hope the wiring will switch over with no problem.
