Installation directions on my Hooker Headers say they will not clear column shifter. What floor shifters have you guys used? I have a 85 Camino with a 4L60E transmission. Thanks
My headers for my SBC in my Regal didn't work for the column shifter and even though my plans at a later date are to add a center console and floor shifter I wanted to drive it before then so I cut and welded the linkage bar and repositioned the mount higher up so it would clear my collector tube and I would be able to use every gear.Installation directions on my Hooker Headers say they will not clear column shifter. What floor shifters have you guys used? I have a 85 Camino with a 4L60E transmission. Thanks
Thanks guys just the information I neededMy headers for my SBC in my Regal didn't work for the column shifter and even though my plans at a later date are to add a center console and floor shifter I wanted to drive it before then so I cut and welded the linkage bar and repositioned the mount higher up so it would clear my collector tube and I would be able to use every gear.
Thanks Fishbait. I’ll check it out.I run a B&M Mega Shifter on my 79 El Camino, but mine has a th350. but the mega shift can work with a 4 speed with no problem.
