So I got my AC sorted out this week. Driving for a couple days ( short trips mind you ) with no issue. However sitting in heavy traffic on the 401 yesterday the AC belt started chirping on occasion which turned to squealing. Only at idle with my foot on the brake and the AC on. Once back to work I popped the hood and with the AC on the belt is bouncing around pretty bad/ I pulled the last bit of slack out of the belt but it still does it only with the AC on.
So here's the question. As I plan to go 1 belt size smaller should I be looking into some kind of a belt dressing ? I assume its the compressor cycling that's grabbing the belt and making it flop and bounce around. I also recall a pic on here in the last few weeks where someone put an idler pulley on the bottom slot of the AC bracket ( I assume to keep the belt from flopping around ). I will sort thru my pile o parts and see if I can dig one up.
Otherwise having working AC is so sweet. It takes about 10 mins to get the car comfortable and about 20 mins before I have to turn down the fan speeds because I am too cold. Keep in mind its only been in the mid 80's this week so I am sure it will get tested once we get the summer heat they keep talking about
