flowtech
I got my flowtech headers in today and the passenger side header is hitting the upper control arm and help wit that so can someone tell me to fix this proble
You get the flowtech or the flowtech afterburners??? Read Ritter's post, three up fron here...He had a slight fitment issue and he described how how took care of it....Anyways, I have the afterburner ones and no issues with them.
I have the afterburner and they're not bolting up when I put the first bolt in the last one is way off and the gaskets holes are off but a couple of cm..
Quick question, You have a small block chevy in your car right? Or is it a Olds powered small block??
Small block Chevy.. I wanted an olds but couldn't find one where I live.. Its getting me frustrated so I stopped for awhile.
I dunno.....straight or angle plugs??
I have no idea bud.....hopefully someone else chimes in. Good luck!! 8)
I found out what's wrong man.. the temp sending unit in the way and so passenger side block off bolt in the way.. I took it off then it worked but now my sendinf unit won't fit now..
That's an easy fix....just use a port on the intake manifold for the sending unit 8)
