Ford 9" compatible rear swaybar?
Reddzedd
21
4
29
Recently got around to installing my the QP 9" into my '78 Malibu. The installation itself went smoothly, but when I went to put the stock swaybar on, it wouldn't quite line up on both sides as it ran into the bottom of the differential housing.
Those of you who have also installed a QP 9" into their G-Body, which swaybar, if at all, were you able to find that fit around the housing?
Use the next hole down on the lower control arm brackets (should have 4 or 5 to choose from). Chassis mounted bar will fix it if you opted out of Instant Center Correction.
