Frame Braces 1984ss
I can't afford it right now that be something to save for.
If you are getting the jounce bars for $25 then I would just find a GP bar or buy the one from Kirbans and I doubt there will be any difference in support over the one piece version.
Reactions: GuysMonteSS
Awesome thanks for the advice 565bbchevy and suggestions I will keep my eye's peeled for the GP bar .
Reactions: melloelky
$230!!!???
I'll stick with my $20 u pull it pieces
The aftermarket unit is better with thicker wall tubing and being welded together as one piece so its more rigid. However, I don't think its advantages outweigh the extra costs over junkyard OEM braces, if you can find them. Sadly G bodies are increasingly becoming scarce in junkyards.
Reactions: Injectedcutty
like anything else,it's to each their own,i didn't buy the part in question.i made my own version out of 1-1/4 dom tube and it's solid.i ran the stock pieces @ one time and decided the stacking process that takes place w/thinner flattened bars one on top of the other was to little to late on GM's part.
