cutlass79 said:if ur taking about the motor mounts that bolt to the frame a socket swivel extension and ratchet to get to the nuts on the under side of the frame thats how i got them on my 79 cutlass
Black Sheep said:Go up behind the lower control arm mount, between the frame and the arm. I use a long extension with a swivel socket to hold the bolt, then use a impact on the nut. Takes some contorting, but possible.
pontiacgp said:if you drop the lower control arm you'll get good access to the bolts and if you think your having problems now wait till it comes to putting the bolts back in
pontiacgp said:when I install engine mounts I use a serrated flanged nut and bolt. I install the bolt up thru the crossmember and mount so when it will lock it self in place and you don't have to hold the head of the bolt with the wrench when your torquing it down..I also use some thread locking loctite on the threads
