Fox80 said:Powder coat sucks, it's just rubber over the metal it provides no corrosion protection. It will hold up ok in a fair weather car but fails very quick if ever exposed to salt or alot of moisture. Pot 15 is ok but not resistance to chemicals and faids bad over time. My frame is painted with summit gloss black and Summit two part epoxy, the body will be done in U-Pol chip Gaurd over Summit epoxy top coated with Summit hot rod (semi gloss) black. You need a paint with a catalyst in it to make it resistant to brake fluid, fuel etc. you don't want to do all that work and bleed the brakes and bubble the paint or have a small fuel leak do the same
