Frame/pinion snubber
pagrunt
9,787
17,081
Elderton, Pa
I am tired of every snubber I find in a junk yard the rubber fall off the mount plate. Does anyone have a good suggestion of what to go with that will mount with out drilling/moding the frame. I know the mount plate might need to be made to fit.
Agreed. Too bad the venders haven't come up with a direct replacement poly unit like the other rubber parts (Venders hint hint)
Take a look at a snubber for a 1972 Chevy K10. One for each wheel. Could you make a plate to match the G bolt pattern, and bolt this to it? Item 14 from the LMC catalog page below.
