Frame removal 87 cutlass supreme
87cutty
106
2
39
I need help removing frame from body. I have trans and motor already out. If anybody had pics or directions on how to do, beyond removing frame bolts and brake lines it would be much appreciated thx.
Remove the front bumper and unplug all the lights. The front clip has to be removed, make note of the shims. Remove the steering shaft. Unbolt the master brake cylinder and secure it if you are not going to remove it. Remove the two wire harnesses from the back of the fuse box. (7mm bolt) Remove the doors and remove the parking brake cable. Remove the rear bumper and the gas tank. I think that's all but if I am forgetting something someone will point it out
thanks to google...
