Front Bilstein shock bolts
Judge Mills
199
Washington State
I'm installing Bilstein shocks on the front of my El Camino. The shocks came with new longer bolts for the mounting on the bottom. The bolts don't seem to want to screw in to the stamped steel fastener. It appears the new and old bolt have a different pitch. Has anyone else ran in to this? suggestions?
why not use the old bolt if the pitch is different. I use a flange nut and bolt on mine
Spaenaur would have the bolts & nutplates
http://www.ss396.com/chevelle/BPX-9715.html
What I originally did, was used longer bolts with the same thread pitch. The Bilstiens I used, had a thicker T-bar for the lower mounting and the stock bolts weren't long enough. You could take the stock bolts and go to you local advanced auto, autozone, etc, and buy 4 new bolts that are longer, and use some flat washers.
I nut and bolt is always an option, like I am using on my Spohn arms, but they are a pain.
I use serrated flange nuts so I can finger tighten the nut then tighten the up with the bolt and I use thread locker loctite
Thanks for the response, guys. Yeah, The Bilstein's require a longer bolt due to the thicker flange. I wasn't sure if there would be enough room to use a nut and bolt. I'll try the easiest route first (new bolts) and go from there. Thanks!
UPDATE: I found some grade 8 bolts, grade 5 nuts that went right in. Even with the grade 5 nuts, I think it'll be stronger than the stamped steel clips.
Reactions: pontiacgp
