pontiacgp said:this is a great system to bleed brakes
speed bleeder
Thanks for the info
speed bleeder
gdouaire said:Ok so here we go for the root cause...
Before reassembling everything, I started looking at the master cylinder and how a 89 Caprice unit works... - well well well... looked like the front & rear portion of the MC were not hooked correctly to the proportioning valve. Read a lot on the web. Yeah, things were mixed up. Re-bent the tubes so that rear/front outputs were swapped.
Once reassembled, it made more sense: the aft portion of the master cylinder, with a large diameter, which meant more break fluid volume was hooked to the front wheels. Also, made much more sense with the adjustable prop valve... when the valve is shut, you don't want it to block the first portion of the master cylinder...
And test drive proved it worked A1....
