CUTLASS Front license plate mount
rfpowerdude
615
975
Palm Bay, Fla
Since this car has the 1988 H/O body kit on it, I am trying to figure out if I should just cut off the bottom of the original Endura tab shown in the pic. Since the front dam tucks under the original bumper cover, it now sticks out some.
It pushes the top of the plate mount out seemingly too far. I do have the original under bumper nylon inserts. Not sure what hardware type is supposed to be threaded into them.
Here is the original plate mount
Thoughts on best practices here so I don't have any stress on the plate mount screw points? And what hardware is supposed to be used?
I want to mount the H/O front plate as I am about to insure and register the car again and actually start driving it again!
jcelk
39
22
8
cut the tabs off or open them up with a dremel so the plate mount fits inside the holes..as for the inserts in the bumper i have seen 1/4 20 bolts and large screws used they need to be snug but not to hard to turn in otherwise the inserts will break same goes for screwing on the license plate and kudos for getting her back on the road
rfpowerdude
615
975
Palm Bay, Fla
I'm hoping 69hurstolds jumps in as he would probably be able to tell me the original intended mount hardware.
69hurstolds
7,701
16,117
Essentially you have hex head license plate screws that hold the front plate holder.
The parts book shows it being a square peg round standoff plastic push in nut "as required" for the bumper mounting, but my factory-installed ones are just plain flat rectangle push ins upper and lower. I've never seen them on a factory-built car. Not saying they didn't use them, but I just haven't seen any.
Nut call out in the parts book is 559547, long discontinued from GM. Although there are aftermarkets available. I honestly don't get how these could make a difference. Factory didn't use them, but there's a reason they made them.
Here's the deal. These brackets don't fit exactly right most of the time. The back of the upper hold down indentations tend to constantly be under stress and eventually crack/pop out and make the bracket essentially useless.
Sometimes they fit up just nicely. Elongating the lower holes, and perhaps a little creative trimming and shimming (nylon washers behind the upper bracket mounting holes) may give you a better mounting without the strain.
TIP: Reproductions have a little sunken divot of sorts in the front middle of the bracket, while the GM part does not.
rfpowerdude
615
975
Palm Bay, Fla
Thanks Mike, I’ll try mounting it via the bottom screws first and try to adjust such that the top mounts “just touch” then put screws in the top to only lightly hold it there.
And what are the “hex head license plate screws”?
