Trying to put on the front steering parts,can't get the center drag link on without it being bound up...can't manipulate it in without 2 people.Should I carry on and put it in...can't get the joints to move,have everything ready.
I might try it...I have some help here now.You need to remove the idler from the frame and install the drag link to the pitman arm. Then swing over and install the idle back on the frame. The little “triangle piece on the crossmember won’t let you do it any other way.
I would also put the inner tie rods on. It’s gets a little tight on the frame to slide them inI might try it...I have some help here now.
Thanks...will try it.I would also put the inner tie rods on. It’s gets a little tight on the frame to slide them in
