Front sway bar problem
Doug Chahoy
2,565
2,663
Here’s the problem, I installed UMI upper and lower control arms with half inch taller ball joints and Moog 5660 springs, I’m using the UMI end links. The F-41 1 1/4 inch sway bar that was on the car won’t line up. The car is in the air but I have a jack under each lower ball joint to put the suspension at ride height. Any ideas how to solve this latest PITA
Doug Chahoy
2,565
2,663
Aw cmon I may not be a mechanic, but I’m not THAT dumb LOL. I left the bushings and brackets in place on the bar when removed so I wouldn’t have any confusion. It’s riding back a little to much to line up
pontiacgp
blank
Mar 31, 2006
29,270
20,413
Kitchener, Ontario
I'm dumb enough to do that cause I have done that and worse....:oops:
have you checked with the guys at UMI?
Streetbu
Know it all, that doesn't
3,748
11,664
Central NY
Control arms on the wrong side?
Doug Chahoy
2,565
2,663
If you mounted to the end links only where does the center of the bar end up?
Using a jack and adjusting accordingly, I got it together. With these pivoting metal bushing rod ends (which are shorter than stock) I’m lost on adjustment. Do I thread as much as I can into the end or only so far?
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,218
Just Google "sway bar end link adjustment"; there are tons of articles and videos, whichever you prefer. The principal is the same, regardless of the car.
