frustrated help please
dft
29
2
Hello, im trying to remove my bench seats with no success. I have the drivers side done but strugling with a rounded front bolt and the bolt in between the rear bracket. Does anyone have any tips on how to remove the rusted bolts. What tools or tricks have worked.
Thanks
Try a hammer and chisel and cut the nut from the stud.
Doud
Have you tried soaking the bolt with PB Blaster or some other sort of penetrating lubricant? Hopefully you can get the bolt to spin without having to heat it up. Spray it, try to turn it, repeat.
Two tips......soak it in pb blaster and then try some vice grips....if that don't work take a dremel tool and cut one side of the nut barely touching the threads then take a cold chisel or punch to tap spin it once you make a half of a turn the nut will spin off......
