Esotericnem said:I'm having problems with my fuel gauge.....when the cars off, the needle goes a little bit below full, then when I start it, it goes past full.....I know oneeye said it can be grounding issues, where do I find the ground in a 81 Cutlass? Also my speedometer stopped working all of a sudden, please help!
w/ the fuel gauge it could be anywhere from the gauge all the way back to the sending unit, have you done any interior work recently? The wires run (at least on my GP) along the passenger side. But yeah that's a bad ground no doubt.
As for the speedo, does it do anything at all or absolutely nothing? Start simple, check the connections at the trans, behind the speedo (had mine come off the back of the speedo once!), and if yours has the cruise module in the middle, check those too. If it still doesn't work check the cable(s) by disconnecting them and hooking a drill up to one end and see if the other end spins.... If it/they spin then I'd look at a busted speedo gear on the transmission or a just-plain broken-inside speedo.
HTH!
