jrm81bu - that's what I was thinking at first, then I looked into the extra injector thing. These little engines only need a few hp to run them, they can be programmed to use smaller injectors without problems at all and without running them at maximum capacity, it'll just go slooow. I guess my question was - is it possible to get a tune to fit smaller injectors when doing 95% of around town driving...they don't have to be 50% capacity of the original, maybe 75% or something. Surely it would force the engine to suck less gas if programmed correctly... no? Then when you need to get on the onramp or somethin, just punch it to WOT and you've got all 90hp on demand :lol:
But your over complicating it. You can't get away using any less gas to make it go X miles an hour at X rpm and stay with a safe a/f ratio, than you can by a custom tune. The tune would just hold the injectors open for a shorte time. Now there may be an instance where you could get away with less fuel than what is delivered by the stock injectors at there shortest opening time. Then using a smaller injector would help.
kingcolbert - It isn't a question of running lean, just giving less gas all around and less air. Can I run the engine in my cutlass with a 350cfm carb instead of a 770 and get better mileage? Answer is yes if I tune correctly, same goes for injectors
If that's all you want to do, get a ac solenoid(the thing used to kick up the idle speed, I think thats what its called), and install it backwards so that it limits how throttle you have when its powered and then flip the switch to give yourself full throttle.
It's just an idea that might gain a few mpg's. Is it worth all the extra money? Probably not unless I could find a cheap SDS controller (those two don't belong in the same sentence). I have free programming plus cost of shipping to wait4meperformance, so the tune would be the cheapest part but it might take a few tries to get right
