I'm working on getting a new engine sbc 355 running. I heard the engine run before I bought it and it was good. I put my holley 4160 4bbl on it ran a new fuel line. Dbl checked for tdc and all spark plug wires are good and connected correctly. When I go to start it it runs erratically -ok for a couple second - then it will slow down and die. If I restart it and try to keep it running using the gas pedal it will still do the same thing except it will backfire through the carb before it dies.
Can this be caused by to many bends in a fuel line or a fuel filter issue? When I say bends I mean 90 degree bends using preformed -6an fittings not accidental kinks in a metal line per se.
