fuel line mod for performer carb...
83cutlasssedan
239
45
Manitoba, Canada
www.cardomain.com
Is there any sort of elbow fitting you can get that you screw into the end of the fuel line in front of the carb so I can connect a rubber hose to go around the side of my new edel carb I am trying to put on. I'm talking about where the fuel line holds the fuel filter and then screws into the front of a rochestor carb. I don't want to have to cut the existing fuel line. Is there a way to connect the the end of that line to a rubber hose?
Thanks
If you don't want to cut the fuel line you're better off plumbing a new one from the pump to the carb. You can theorectically plumb a fitting into the end of the hard line but why bother, plus that's just another potential leak point.
Does your current setup have the hard-linecoming straight into the carb or does it come in from the side? Engine & carb info would be helpful.
