Full floor pan replacement question
NCTyphoonKid
654
2,026
For those that have done the full floor pan replacement what are you doing about the rear edge at the rear seat along with the driveshaft hump (circled in red). I know all the pans are stamped after a el Camino so it’s different than a Regal. Looking for some input as I get ready to tackle it in my car. I’ve seen some that were cut and welded kind of low just looking to see if anyone else had any better suggestions.
I overlapped about 1in. You'll have to trim it a few times to get it to fit. I pulled the pan in and out atleast 5x. I used self tapping screws, tack welds and hot hammer work to get everything tight. I didn't wanna cut it out real low. I wanted my lap to be up higher.
Here's where i cut the pan at
The red line is where i cut the hump at to get it fit together. But when i flipped the car over i had to cut a portion out. Then i tacked and hammered it till it was flat and tight.
The key is to use the heat to your advantage. Its alot easier to move hot metal. The 2 pcs should be as tight as possible before you lap weld or you'll just blow holes.
I overlapped about 1in. You'll have to trim it a few times to get it to fit. I pulled the pan in and out atleast 5x. I used self tapping screws, tack welds and hot hammer work to get everything tight. I didn't wanna cut it out real low. I wanted my lap to be up higher.View attachment 158661
Here's where i cut the pan atView attachment 158664
The red line is where i cut the hump at to get it fit together. But when i flipped the car over i had to cut a portion out. Then i tacked and hammered it till it was flat and tight.View attachment 158666
I like that it looks good I have my floor in my car cut similar to that now actually
Reactions: pontiacgp
RabbitHoleSS
Where did you get that new support brace?
I have to tell you guys, some of the work you guys do to put these cars back in shape is really impressive. I can build a motor with the best of them but I can't seem to get the hang of working sheet metal like you guys do. I have two welders, cutting torches, a plasma cutter, cutters, grinders and a shop full of other really cool crap but my sheet metal worth isn't worth a damn. I'm getting better but it just doesn't seem to come easy. I'm retired now, so I will get there but I still have a loooooooooong way to go. My hat is off to you guys
hello guys. i am new to the group. i need my floor pan repaired in my 82 monte. who normally do that type of work? is it the body repair guys or paint shops?
