in my 1980 olds cutlass there is suppose to have two fusable links coming off the starter mine has none just 14 gauge wire so no protection. not good!!! what size is the fusable links suppose to be?
My jet boat had themparts store should have it but I would phone first. The statute of limitations have expired so I can tell you I "borrowed" some 20 amp aircraft breakers when I worked in an aircraft plant and used them instead of fusible links in my 74 GP. These are slow burning breakers that can be reset and I thought looked cool with the other "borrowed" breakers I was using...
