G Body After Market Rear Trailing Arms, Which Type??
I've had a the Jegster units from Jegs for a couple years without any problem. I also got the lift kit which lowers the mounting point of the rear of the lower arms. I can't tell any difference in handling but it definitely makes for a better bite. If you use the lift kit, make sure you are very careful about drilling the holes because if they are not the same on both sides, the car will crab-walk. If you are going to launch hard, I'd get the little braces at the same time if you exhaust is will not interfere. That will stiffen up the mounting points for the lower arms on the frame.
Later,
Pat
