G-Body Delay Wiper Motor
Trader history (0)
Camino Man
n00b
May 3, 2015
74
Pulled from a Malibu Classic--Works--part #'s in Pictures--Will fit most g-body cars fro 1979-1982-as pointed out by another member !!-- I am in BC Canada---$135 free ship to the lower 48---and anywhere in Canada
open to offers !!! Ended up with 2--Tested in the car before I pulled it--Send PM for further info--Pay-pay only !!--Thank-you !!
Reactions: Sweet_Johnny
That's some hard to find goodies right there!
Reactions: Longroof79
That's an earlier type wiper motor with cam driven mechanism for earlier year G-bodies. Pre '82.
The motor itself was built on Wednesday, Nov 7, 1984. (date code 312 84). Appears to be a factory number, not an over the counter GM number. 20521246. It was made 77 days prior to the original one in my 85 442 (84 was a leap year). Keep in mind these are production plant numbers that came as an assembly, not parts catalog numbers which you buy the pieces separately.
How can you tell it's for an earlier than '82 version? To me, it looks like a CD4 84-up unit. An FYI, ALL the skinny style wiper motors from 84-up are the same regardless of delay or non-delay, including the park switch. The only thing about delay is if it has the circuit board cover and the "contactors" that are mounted on top of the park switch.
This is my original from my 85. 20521247. The interesting part I see there is that it has 4 electrical connections. Meaning those three in a row were used for the park switch. That extra one was for the circuit board power. There's also a 20521248 out there as well that I believe came along in 1988 or 89, same unit basically. Again, motors and park switch are all the same. The cover and contactors determine if it's a delay unit or not.
Reactions: xylorex and Rktpwrd
Sorry, I screwed up. I should have looked at it closer and known better.. That's what I replaced my old type wiper motor with.
PULLED FROM A 1979 Malibu classic !! You are probably right ---Likely is !!---Thanks for the heads-up !!
Sorry man, I 'm wrong. Please excuse my oversight. That is in fact the later type wiper motor. My bad.
All I can tell you is that it is the exact fit for my 79 Camino--what else it fits YOU be the judge--I believe it a great buy and it is for sale--Thank-you !!
I know that the delay wiper parts are getting harder to come by. Also, the later delay wiper motors must be compatible with the proper switch. In that case a stalk mounted wiper switch that's configured for pulse or delay. .
Put delay wipers off 1987 Monte and tilt steering column(took all wiring from 87 Monte) from 87 Monte had column rebuilt a the man that rebuilt it put correct turn signal lever with delay.
This all was put in a 81 Malibu.
