Shift lever on the column or on the floor? On the column and the Neutral switch is located down on the mast below the ignition socket. On the floor and it ought to be attached to the floor shifter inside the console.
Check the neutral switch to make sure that the vehicle is going completely into park at the switch. If the little finger on the bottom of the switch that indexes into the slot on the steering column is worn or bent or damaged then the switch will not consistently fall into park and you will be unable to start it.
If the culprit, then with a column the switch is held in place by two screws that are metric headed, I think, You can both see it and get your hands on it if under the dash but getting it out usually means that you have to drop the column to get more room for the job. Yes it can be done with the column still resident but lots more finagling and cussing involved.
With the console shifter, you have to partially dismantle the console to get at the shifter mechanism. Beware the screws as they are small and love to try to escape and hide.
nick
