what length is the battery cable for the positive cable to the starter a d what gauge?Thanks
Yeah, it's one of those things where (at least on older/project cars) everything get's replaced in starting and charging systems because there's not much involved right? Battery, cables, starter and alternator and that usually fixes any problem cuz everything's been replaced. It's those ones where all that's been done, or none of it's been done (yet) and you just want to replace/repair what's actually wrong.Sponge Bob mentioning that clutch neutral switch kicked waaay back into the past 1975 to be exact. The V-8n Monza that I owned back then had exactly that feature. To prevent inadvertently starting the car in gear you had to bottom the clutch pedal all the way to full stop to actuate a switch that would allow the key to spin the starter. Major nuisance. Supposed to be a safety feature but more a memory check for newbies who only had ever driven automatics.
As for wire resistance and voltage drop over distance versus wire gauge, that particular topic ought to be in the library as it was a subject of a whole series of threads some years ago. Not sure which side of Covid it falls on, pre or post, in terms of how far back but it has been a repeat topic of interest from time to time. The audio geeks on board are the best references as they are OCD for heavy gauge for their amps and woofers.
