I had the same problem about a year ago. I had a 2004r at the the time of the vibration. After I destroyed that trans I installed a Th350 and the vibration went away. Ended up being a bad tail shaft bushing. Hope you can figure out your issue.
smokes468 said:I'v been fighting this problem ever sense i installed a 9" last year...
pontiacgp said:smokes468 said:crazy87 said:Normally a high speed shake is a balance issue, low speed shake is a component issue, loose u joint etc. Do you have a u-joint tight in the yoke? Remove the driveshaft and make sure the rotate smooth. Try pulling the tires first then the axles and eliminate shake while running in the air. I would think if the brake drums were the issue you might have a brake pulsation in the pedal. Without seeing/being there it's always hard, I hope it helps good luck.
I'v had the tires off & on he stands, it does seem to be smooth.
were the stands on the axle tube or the frame? I would put the wheels back on with the stands on the frame and try it again
GhettoRacingKid said:Does the vibration increase with speed?
If you are running a spool which i feel you are. It sounds like your rear isnt straight so your getting bind.
Or its the trans. Swap the trans. See what happens.
