drb930 said:What is the best spindle to use on the G-body for handling?
Is the B Spindle the best choice out there now?
I am doing a C-5 conversion on a 87 ElCo.
Thanks,
Dave
I was in the process of peicing together a b-body spindle setup. I ordered the Global West arms for the conversion. Due to the b/f-body spindle being taller, a shorter upper a-arm is needed. Well, when I ordered my GW arms I called and toldthem I was wanting to do the b-body spindle swap and they ended up sending me the wrong arms. Notknowing until a few years later did I find this out unfortunately. A call to GW and an explaination these arms had never been mounted got me no-where with their sending me the wrong arms. I sold them for 75% of what I bought them for new.
I talked to Marcus at SC&C and ne convinced me to retain the stock g-body spindle as the f/b-body spindle swap has it's share of problems. It does improve the caster and camber but the bumpsteer is not even close to being ideal. Apparently it can be fixed but there are now better solutions.
Since I had bought all my swap parts years ago, many newer and better ideas and ways have come along. Enter Marcus at SC&C. He sells both a stage 1 and stage 2 setup using the stock g-body spindle yet also increasing the cars handling. Both use a custom tubular upper arm. Stage 1 uses a taller upper ball joint and stage 2 uses both upper and lower upper balljoint. In a PM to Marcus he told me the improved geometry is as good as a 2002 f-body.
But, that's for the handling and you asked about the brakes. Ed Miller at www.flynbye.com sells the bracket to mount the C5 caliper to the stock g spindle. You mount this to the dust shield holes with the included grade 8 bolts. Mill the brake portion off your old rotors (or any worn-out rotors since you're not using the *brake* portion of it) and use the hub to mount the Vette rotor which has no hub section. You can get replacement parts at any auto parts store as they are stock 2000 Corvette parts. Tobin at www.kore3.com sells a pair of new loaded front calipers and brackets for $300. Napa has re-maned units but they also carry a core charge and cost almost as much as these new ones. 13" plain (not drilled or slotted) rotors fome Napa are $45 ea. The brackets from Ed are about $75 for the pair. So, you're looking at somewhere between $500 - $500 for 13" Vette front calipers and rotors on your stock g-body spindles. But, be forewarned, these brakes need 17" wheels and not all wheels will clear the Vette calipers. Kore 3 has a downloadable template to check if the brakes will fit your wheels, provided you already have them. Both Tobin and Ed also has hybrid kits to fit other wheels. Best bet, call Tobin at Kore 3 or Ed Miller a call and they can guide you to exactly what you need.
Next time you see somebody with fancy Baer brakes just remember, your brakes are just as good for less than half the price. Or, you can add the both the front and rear disc brakes for what they have in just their fronts :lol:
