Does anyone know if any company makes a reproduction gauge cluster housing. The one from my Monte SS is in very rough shape.
I thought some years back (20+) I saw repop gauge housings on the market but like lots of G parts they came & gone as fast as they showed up. At this point a good used one maybe the way to go. One thing to keep in mind is there is a slight change in '86 due to the change in the bezel & headlight switch bracket which removed the left & right side screw anchor clip mount points.Does anyone know if any company makes a reproduction gauge cluster housing. The one from my Monte SS is in very rough shape.
That's for aftermarket gauges, and has no provision for the OE gaugesThey make the housing itself if that is what you need.
Brian is correct that is for an after market shadow box, I'm not sure what the OP is looking to do but That being said I'm using one of those and it worked out well.They make the housing itself if that is what you need.
