Gauge pods
MetroRob
148
121
Has anyone used these
565bbchevy
9,614
12,683
Michigan
MetroRob
148
121
I bought one years ago and didn't like it, it was too flimsy and was missing the outer edge that wraps around the pillar facing the outside.
how was the fit ?? I can make it pretty if its close to fitting
565bbchevy
9,614
12,683
Michigan
If you are sitting in the passenger seat it would appear to fit ok but I didn't use it because the outer edge that was not there you could see the metal between the door seal and the pillar pod so I ended up using a dual pod and mounting it directly to my factory pillar.
Lacking that outer edge made it flimsy, you could probably cut off the part from your factory pillar and glue it on but the whole point of buying this for me was as a pillar replacement which it was not.
565bbchevy
9,614
12,683
Michigan
Maybe ask for a picture from that view, who knows they may redesigned them since the time I bought mine years ago.
abbey castro
1,048
1,318
Harker Hts TX
These are not replacement for the full pilar trim. Mine also doesn't go all the way around to the inside of the pilar like yours but fits well.
Ernest
745
1,007
Texas
Abbey Castro.... now thats what i like, full spread read out no matter what the guage.
MetroRob... i have the 3guage pillar pod, it came with my 79' malibu, Tach, oil pressure and water temp, i dig the location for easy viewing, but it doesnt exactly fit well, it gaps the window side a tiny bit.
