gauge replacing
mkube396
132
10
South Buffalo / West seneca NY
Has any one been able to fit “cheep” sunpro gauges in to replace there stock gauges? Just looking for size I think I would need 1.25” to fit we sell a nice set of 1.5” at my sec job << work at a autoparts store to
if any one has pics that would help thanks..
I am only looking to replace the middle 4 “volts, oil psi, temp, and fuel...
I wondered that myself. I have a regal and would like to replace the noisy in dash clock with a tach, looks like it'll fit but I haven't tried it yet.
Idk but i equus got them Walmart gauges for 45 n dummy the Lights places but they have 2.5 tach. That fits good. I spent 165 For all the gauges I hope this help you
What size are your speedo and tach, 3 3/8"? From what I've ascertained , the 5" tach and speedo look like they would fit the opening a little better. I have a Pontiac dash that I plan on installing.
yes my speedo and tach are 3-3/8"...they fit in the stock opening with a little work...to go 5 inch you would have to make you own housing for them to sit in and they probably will not align with the opening in the trim
*Edit*
I guess you could fit 5 inch, but would they fit recessed like the others? or more flush with the trim?
Thanks guys.
It looks good either way. Whether they're mounted flush or recessed. I would prefer mounting mine recessed like the original gauges. I have even considered using the stock Pontiac tach and speedo. However, the under dash wiring had been cut when I removed the dash. I just assumed I'd be using aftermarket gauges anyway. That was a bit of a mistake.. 😳
BTW, your gauges look good in there.. :wink:
pontiacgp said:
Jack, the speedo and tach would be a 5". He has the same dash I have in my GP
I also used a 5" spedo and tach in my GP dash and they fit perfect. I also used 2 5/8ths accesory gauges.
