Do you have any ideas on how I would fix it ?I think it's the key buzzer. It is supposed to only work when the key is in and the door is open. It doesn't work on my car so I'm not sure. It could be the headlight warning chime, which is supposed to warn you when the key is off and the headlights are on.
Do your dome/courtesy lights work normally?Do you have any ideas on how I would fix it ?
What color is the box?and What do u mean by plug it ?There is a little box under the dash somewhere. It is about 1 1/2 " square and looks like it has a speaker in the middle of it. In plug it and your buzzing will go away.
My ceiling light?Do your dome/courtesy lights work normally?
