I know when I first started to build the MC with the Camaro 350 I wanted to put Patriot side pipes
on the car. For one I had never seen a monte with these. After getting the pipes and the almost
impossible connection configuration from the header collector to the (behind the front wheel )
side pipe connection , which took multiple exhaust parts welded together to make a real tight "S"
bend. It sounded good and looked great. However at speeds around 60 mph the exhaust drone
was so loud it was uncomfortable to drive. when we pulled the motor due to a bad crank, i pulled
the side pipes and sold them in favor for straight duals out the back.
While under the car I installed an "H" pipe and 2 1/2" SS exhaust all the way to just in front of the rear
axle. With turn downs. And tried that first. Same issues. Loud drone harsh enough that the
car vibrated at some speeds.
I then purchased the muffler to rear exit (SS monte style) 2 1/2" pipes to finish off the system
and put the exhaust exit out from under the car. system works great and drone is all but gone.
Nice exhaust sound at idle and when on the gas. At cruising speeds it sounds almost stock.
Gone are the drone and vibration from before.
If you have similar stories please share.....
