well i could use some more info on the car and what it will be used more for .....but i will say if your going to use it hard and have lots of hp i would go with a ford 9 inch .they are proven on the track for years to last i think its the best bang for your buck.i know i can build a custom ford 9 with disk brakes for less than a 12 bolt rear ....i am running a ford nine in my car with rear disks with np.but on the other hand the gm 12 bolt can hold its own too but will cost you in the long run by the time your done with it ,its also alittle wider but could help you on the track with wider tires ,i have seen some people cut off the stock flang and weld in ford nine flanges ,i just like the idea of taking 40 min and swaping gears out with my ford 9 just by removing a few bolts.its a plus for a 3 speed transmission car set one up for cruzin and one up for the track .
