That is interesting and if a gov lok was the only option it would be very helpful, personally I'd go with an Eaton posi or truetrac
If you watch the video below on how the G80 works, it actually has more clamping force than a standard clutch type posi. The G80 does have a reputation for coming apart there is no doubt. I believe that is due in part to the very violent way it locks up. I am going to continue "testing" on this rear end, but I believe that lowering the differential engagement rpm will keep it from shock-loading the internals and turning them into confetti. I'll keep beating on this one, and if it explodes. There will be pictures below.
The more I read, the more Im thinking Im going to skip Auburn and go with a Detroit TrueTrac, even tho they cost a bit more.
-Gonz
