GN louvers?
Jman
203
2
Ontario
they are functional, and the fenders need to be cut. i added them to my monte and love them.
FE3X CLONE
2,714
52
48
Ohio
84regalltd said:
Thanks man. Not sure if I'm gonna go that route or not. What are the benefits?
I can't say how well they work but their purpose is to help air escape from the engine bay. I had them on my Cutlass for a while but decided not to keep them.
Jman
203
2
Ontario
they let alot of hot air out
84regalltd
Jan 3, 2010
74
Marietta, Ga
How much of a pita was it to cut the fenders? Getting the extra heat from my headers out. Sounds like a good thing. Any worries of paint discoloration around them?
Jman
203
2
Ontario
wasn't bad at all. i made a template for it, traced out what i wanted to cut, then masked it off and used a small cutoff wheel. worked great.
mkiiisupra
407
16
Versailles, KY
In order for them to be fully functional as they were on the GNX, you need to cut the inner fender as well. http://www.kirbanperformance.com has the inner fender bezel that the original GNX setup used as well as the louvers. The original setup on the GNX had some sheet metal fabricated to allow the air to flow out. This link will take you to a site for all the stuff under the hood that you will need
http://gnsperformance.com/gnxfenderkitpage.html
name=Forums&file=viewtopic&t=708The next link is for the actual louvers from Kirban http://www.kirbanperformance.com/produc ... LOUVERS+(2)+%231541.html
This link is for the incomplete inner fender kit from Kirban
http://www.kirbanperformance.com/produc ... RACKETS+(2)+and+INNER+FENDER+LOUVER+BEZELS+(2)+KIT+%237117.html
scot w.
Seymour, TN
We offer the only GNX vent kit on the market tody that will make your louvers Functionable! With many vendors out there selling the louvers and only bits and pieces of the vent kit WE DO NOT SELL THE LOUVERS!
Our complete GNX vent kit has step by step instructions, Templates (for cutting the holes CORRECTLY), and ALL needed harware just like the originals did from ASC right down to the correct clips,fasteners and screws used on the original GNX's.
So if you have the louvers and want to make them functional This is the kit that will do that..
Check it out at -> http://gnsperformance.com/gnxfenderkitpage.html
Scot W.
