Good How To Video from RoadKill.
MrSony
6,831
6,741
Des Moines, Iowa
Saw it. Good stuff. This is partly why I pay for their service. This is one of many "tech" videos they have and will have.
Ribbedroof
4,904
7,013
Wellston, OK
Or, you could use one of the many online calculators
I do like the whole Roadkill/Hot Rod Garage series
MrSony
6,831
6,741
Des Moines, Iowa
It's good to know the actual formula, instead of having to look up a calculator that might be wrong.
Ribbedroof
4,904
7,013
Wellston, OK
How do you know Freiburger is right? Just sayin'...who checks the checker? ;)
I used to use a formula that we were given at BF Goodrich, which used the loaded radius of the tire rather than OD. Was a little more accurate, but not really enough to make a BIG difference.
MrSony
6,831
6,741
Des Moines, Iowa
I've used it.
RPM= mph x rear gear ratio x 336 divided by tire diameter.
So, with my regal, 2.41 gears, TH350 with a 1:1 final gear, and a 195/75/14 tire with a diameter of 25.52 inches, that comes out to 2,379rpm at 75mph. My tach read about 2400-2500rpm at that speed in my regal. And as stated in the video, if you have an OD transmission, on, say a Th200r4, you multiply the rpm (in this case, lets use my 2,379rpm) by the overdrive gear ratio which for a 200r4 is .67. So 2,379 x .67 = 1,593rpm. Math is fun when it's about cars. I sound like a math teacher, but sometimes (especially with cars) it's better to know the formulas for things. Yes with the advent of phones this info, and this video, are just a few taps/clicks away, but it still helps to know.
