They told me the same thing about my Lemans' hood on my wagon. They are very accomadating. I am still running the steel hood with the shaker for now. I am going to assume you have a steel hood now. The Trans Am shakers vary depending on what engine they were intended for. An olds 403, Pontiac 400, 305 Chevy etc. I used one from a 403 and it required major modification to the air cleaner base. The carb is not centered on the 403 piece and I doubt it is perfectly centered on any of them. I would guess one from a 400 pontiac would be the best starting option for a Pontiac motor, and the 305 one for a chevy motor. Doing it purely on measurements, you will screw it up. Best to mock up the engine in the engine bay. Install the shaker. Then take measuremnets from that. Cut an opening in the steel hood and see how it fits. Now that you have an opening you can make a template of the shape ( and make any adjustments for location) and supply VFN with measuremnets from each corner of the hood to a single spot on the template (probably in the middle....make a mark). I've seen the shakers go on Ebay for $400 and up in good shape and complete. Good luck.
