Grand Cherokee Steering Shaft --Didn't fit
kartrac3r
112
16
Kearney, NE
Bought a steering shaft off of ebay that was out of a 94 Grand Cherokee. D-shaft was 5/8" wide. Thought this was what I needed but my steering column end is 3/4". whoops. I thought what I needed was a 93-98 grand cherokee shaft, were there other styles?
Your talking about the intermediate shaft? dixiemontecarlo has new ones for 82-88 G bodies.
Some Cherokees also have this shaft. Is the steering wheel side made of steel or aluminum? I have the one with the steel end and had to pry it open a bit and filed down where the bolt goes through a bit and it fits perfectly..As for the shaft not collapsing try soaking it WD40 or PB blaster and hitting it with a rubber mallet to loosen it up.
I believe mine had the aluminum end on it. I could grind on it, but I dont think the bolt would clamp. Both sides clamp down instead of one going through the steering column end
You need the one with the steel end i did the same thing and pulled the aluminum one off a Grand Cherokee first and it didn't fit either. I then pulled one off a Cherokee and it fits.Either way the shafts with the steel end are more common on the Cherokee than the Grand Cherokee.
There were a few Cherokees today at the junk yard i went to today.Pm me if you can't find the one you need.
Question:
What's the point of this? Is it just for looks? Been wondering this for a while.
Phoenyx said:
Question:
It does not use a rag joint like GM does. It gives you tighter feeling steering and shouldn't wear out.
