It depends on the calipers used.82-87 F cars used a Delco-Moraine caliper that was cast Iron and had a smaller rotor than the later models. 88-92 F cars used a aluminum PBR caliper and a 11 or 12 inch rotor ( don't remember exactly). It is the better of the two as it has a parking brake that does not go out of adjustment as much as the earlier design. I am not sure of the S-10 or 4th gen F cars brakes, so I can't comment on them here. The other 2 possibilities would be the 1975-77 Cadillac Seville discs or the discs off a late 2nd gen F body like a WS6 Trans Am. Discs were even available on 1st gen F bodies under option code JL8, but are rare enough to be highly unlikely as a swap candidate. It's interesting to note that the mounting flange on a G body 8.5 is the same as all of the cars I mentioned. Also, disc brake 7.5's use the same flange as the 8.5. The drum brake 7.5, however, uses the unique 3 bolt flange that makes interchange more of a challenge.
